STR8E180 2,214 Posted October 7, 2012 If your going to use the 3071 make sure it's the full gt30 trim The t3 external gate 60mm trim has got to be the most responsive turbo for it's power output I have ever come across and it does it so easily Share this post Link to post Share on other sites
STR8E180 2,214 Posted October 7, 2012 .. I've read plenty of good feedback on the Kinugawa, but usually only after just being recently dyno'd. I've also read good things about them on the interweb but all those reviews are people running them on low boost figures so no one had really put them to the test yet I would like to see how they handle big boost levels Share this post Link to post Share on other sites
sc s15 10 Posted October 7, 2012 Mase, yours is the t25 internal wastegate version isn't it? How do you find it? Decent response still? It's such a hard choice, The GT3071r is probably better, but not sure if it's $700 better. All the dyno charts I can find seem to be very similar, but obviously they don't show how it actually drives. Share this post Link to post Share on other sites
STR8E180 2,214 Posted October 7, 2012 The T2 56mm trim 3071 does not compare to the full gt30 version Share this post Link to post Share on other sites
Mase 1 Posted October 7, 2012 Yes mine is the T2 version.The torque goes up at about 75 degrees on the dyno graph at 3300rpm onwards. I had the intercooler upside down under the rad support to shorten the piping. I found it quite responsive. I did have to port the internal wastegate path to get some better boost control at 23psi but it worked well. You could spend the $700 change on an E85 setup though for an extra 30kw's. My 2000cc injectors and high mount china fuel rail were $720 delivered. Share this post Link to post Share on other sites
sc s15 10 Posted October 7, 2012 I would get the 60mm version if i got the gt30. That's a good point mase. Are you going to run pump or drum e85? Share this post Link to post Share on other sites
Mase 1 Posted October 7, 2012 Pump, the price difference is significant. I think i'll just try and stick to the one fuel distributor. I haven't put too much more thought into it though as the car is a while off being finished, let alone running on E85. Share this post Link to post Share on other sites
STR8E180 2,214 Posted October 8, 2012 Haltech Have a fuel flex sensor it's f+*king awesome !! It adjust the tune According to the ethonal content of the fuel It allows us to push the tunes all the way to the limit off the fuel where as before we had Leave a leeway incase the fuel was low in ethonal For example if tuning on e85 the car was tuned to e75 to give the engine some leeway in case of lower ethonal content from the pump Where as Now with the flex sensor the ecu will make adjustments to the mapping in real time it allows us to really push the limits of the fuel with out needing to leave any leeway of lower ethonal content Share this post Link to post Share on other sites
sc s15 10 Posted October 8, 2012 Yeah I saw that fuel sensor thing, looks like it would be a good bit of gear. I'm not in the market for a new ECU though. Ended up buying a TD06SL2-20g today. I guess I'll find out in a month or so whether it was the right or wrong choice. Share this post Link to post Share on other sites
sc s15 10 Posted October 16, 2012 A few goodies arrived today. 6Boost manifold, Tial gate and Kinugawa TD06sl2-20g. Won't be installed and tuned until after the middle of November once the season is over. Share this post Link to post Share on other sites
CaBS 6 Posted October 20, 2012 Loving this build man keep the footage coming! =) Share this post Link to post Share on other sites
Simonster 0 Posted October 21, 2012 Nice work! Thanks for posting the insert pics, will help me with mine. Car is coming along nicely! Loved the video on your first post, what a shame you missed the gear. Keep the updates coming!! Share this post Link to post Share on other sites
sc s15 10 Posted October 24, 2012 (edited) Thanks guys. Simonster - If you're doing a similar thing with your shocks and need some pipe I have heaps left over that you can have. I've been doing a little bit of shopping lately, just purchased an S15 cradle and some GKtech conversion bushings/subframe risers and weld in subframe reinforcement plates. Also bought some Z32 rear knuckles - for those that don't know they're aluminium and reduce unsprung weight by about 2.5kg per side. They bolt straight on apart from having to change the coilovers to fork mount. And some Nagisa Auto front roll center adapters, one of the few brands that actually correct the roll centers by extending the ball joint shank, not just moving the ball up. Edited October 24, 2012 by sc s15 Share this post Link to post Share on other sites
sc s15 10 Posted October 27, 2012 A little project I've been working on for the last couple of weeks, making a wing that actually resembles an aerofoil. It has turned out pretty well, although if I did it again it would definitely turn out a bit better. Almost finished, just need to make the endplates, paint it and drill the holes for attachment. It's definitely going to be stong enough and it's around the same weight as the carbon fiber one I'm using now. Share this post Link to post Share on other sites
scooby36 2 Posted October 27, 2012 (edited) hotsauce, great finish on the curves, ready in time for next weekend dya reckon? - should be able to run less angle for the same DF level, less drag = win Edited October 27, 2012 by scooby36 Share this post Link to post Share on other sites
sc s15 10 Posted October 27, 2012 Yeah, definitely finished for QRDC next weekend. Hoping i'll be able to run a lot less angle than before. Share this post Link to post Share on other sites
CaBS 6 Posted October 27, 2012 Thats very cool indeed I'm guessing you've done some sheet work prior to this? Share this post Link to post Share on other sites
sc s15 10 Posted October 28, 2012 Yeah, I used to be a boilermaker so I have a fair amount of experience working with metal, not much with stuff this thin though. Anyone with half decent hand skills would have no problem making one though, apart from welding the uprights to the tube. Share this post Link to post Share on other sites
jlux986 1 Posted October 28, 2012 hey man, It is good to know there are other dudes out there tracking there cars! I am keen to do a few races in my track 180sx also, next year is the year! sweet ride mate! Share this post Link to post Share on other sites
jlux986 1 Posted October 28, 2012 What does it cost to run at these race meetings ? are there different categories to enter in ? I would almost bring my car up and do a few events up there next year !! Share this post Link to post Share on other sites
Mase 1 Posted October 28, 2012 It looks great but why didn't you just do the lazy man thing and buy a $50 wing off boost if you wanted it like that? What is the internal structure made of? Ply? Share this post Link to post Share on other sites
sc s15 10 Posted October 28, 2012 Race meetings are about $200 for the day, not much more expensive than sprint days. I run in Outlaws sports and sedans, we basically have no rules, run whatever you want, modified however you want as long as it originally had doors... Internal bits are made of ply, I figure it was good enough for planes for 50 years it should be good enough for me. I was looking for a decent wing but all the ones I've seen that were under $1000 don't look like they're made to do anything, just for looks. I've basically used a profile between the Kognition wing and APR gtc-500. This has cost me under $100 to make so it's no big deal if it isn't perfect and I have to remake it, I guess we'll see how well it works this weekend. Share this post Link to post Share on other sites
Mase 1 Posted October 29, 2012 Fair enough mate. The blades on some of the cheapy wings look a little similar to that which is why I asked. Great job on the fab skills. What are you going to make the end plates out of? Share this post Link to post Share on other sites
sc s15 10 Posted October 29, 2012 End plates are 2.6mm Aluminium. All mounted and ready to go, just need to paint it if I can be bothered. Made it adjustable from 0 to about 18 degrees AOA. Share this post Link to post Share on other sites
Simonster 0 Posted October 31, 2012 Thanks guys. Simonster - If you're doing a similar thing with your shocks and need some pipe I have heaps left over that you can have. I've been doing a little bit of shopping lately, just purchased an S15 cradle and some GKtech conversion bushings/subframe risers and weld in subframe reinforcement plates. Also bought some Z32 rear knuckles - for those that don't know they're aluminium and reduce unsprung weight by about 2.5kg per side. They bolt straight on apart from having to change the coilovers to fork mount. And some Nagisa Auto front roll center adapters, one of the few brands that actually correct the roll centers by extending the ball joint shank, not just moving the ball up. Thanks for the offer! That's good to know about the Z32 knuckles- all the little bits of weight reduction help! The wing looks a decent shape- anything close to the GTC-300/500 should be reasonable. You may find the rivets will have a dramatic effect on aero- I gather you still have the template you used for the formers? It would be a lot more efficient if you we able to make it out of fibreglass ie use the formers like you have but lay some layers in fibreglass and dope it. I plan to do something very similar to mine. Share this post Link to post Share on other sites
sc s15 10 Posted October 31, 2012 Yeah the rivets aren't ideal. This wing is a bit of a prototype just to see how it turns out and how well it will work. It should be fairly easy to remake it still using the same basic frame though if it doesn't work that well. It would be great if I had the skills to make something like this http://forums.bimmerforums.com/forum/showthread.php?t=1306900 , carbon fiber with a foam core. I don't think I'd have the patience for it and I suck at fiberglassing, at least I have some sort of idea with metals. Share this post Link to post Share on other sites
Simonster 0 Posted October 31, 2012 I couldn't open the link but yes foam core would be the ideal solution. Share this post Link to post Share on other sites
scooby36 2 Posted November 1, 2012 (edited) bump- Sam and I are racing both days this weekend in the Outlaws class at QR - on track from 8.30am on both days. So come out and say hi and watch us stick it to the v8s Entry cost $20 for sat or $30 for sun. heaps more racing on sat so it doesnt really make sense http://archive.awebe...TION_SET_TO.htm Edited November 1, 2012 by scooby36 Share this post Link to post Share on other sites
sc s15 10 Posted November 1, 2012 Thanks Cal. Tried to finish getting the car ready for this weekend today. Found that one of the CV shaft boots has split and grease is everywhere. Luckily the s15 subframe I bought came with the same 6 bolt shafts, so I'm just going to use one of those. If I can ever get the nut on the hub end off that is . Also found out that the rubber stop that pushes on the brake light switch has broken, bodged that up for the weekend as well. Maybe I should've looked at the car more than 2 days before the race meeting... Share this post Link to post Share on other sites
Simonster 0 Posted November 1, 2012 If I'm not working online on Saturday ill come for a look Share this post Link to post Share on other sites
