TAARK
SR20ve Parts!
SR20VE/SR16VE PARTS
Return to Menu
SR20ve P12 Rocker Cover
Description:
We have brand new P12 rocker covers in stock. Great for that VE conversion. Allows you to run S15 coil packs and looks great!!!
Comes with the coil pack cover too!
Price: $360.00
P11 Oil Pump Drive Collar
Description:
Always good to replace these when replacing an oil pump or rebuilding a motor. These tend to to wear out and destroy oil pumps.
Also needed for SR20ve RWD conversions
Application: P11 SR20ve
Price: $22.00
SR20ve P12 Camshafts
Description:
These cams are great for your VE conversion. Perfect for turbo setups!
Price: $600.00
Price includes both intake and exhaust cams.
SR20ve P11 Intake Gasket
Description:
Pulling your intake manifold off or doing a VE conversion? Then you will need one of these.
Price: $30.00
SR20ve P12 Intake Gasket
Description:
Price: $30.00
SR20ve P12 Solenoid Gasket
Description:
Pulling your solenoid off or doing a VE conversion? Then you will need one of these.
Price: $10.00
SR20ve/SR16ve 7 Layer Metal Exhaust Gaskets
Description:
If your pulling your SR manifold off, then you need one of these... They seal perfectly and are re-usable. They come standard on the X-Trail SR20vet and will work with any SR20ve or SR16ve!
Price: $40.00
SR20ve/SR16ve Rocker Cover Gasket
Description:
If your rocker cover is leaking... Then replace that gasket! Comes with the spark plug well seals also!
Price: $42.00 (set)
SR20ve/SR16ve Oil Pickup Gasket
Description:
If your replacing an oil pump or doing a VE conversion you will need one of these.
Price: $3.00
SR20ve/SR16ve Oil Pump and Front Cover
Description:
Always good to replace your flogged out oil pump when rebuilding your motor... Or if you are doing a VE conversion you will need one of these.
Price: $250.00
SR20ve CAS
Description:
This is needed when doing a SR20ve or SR16ve head conversion onto a RWD block. Originally from the P12 Primera SR20ve (20v) motor.
Price: $350.00
Hey TAARK, just wondering if you are able to get the studs that go into the backing plate on S13 R200 diffs.
Cheers,
Alex
hey taark, im still chasing that rocker cover gasket and spark plug gasket set for my s13, but i need like forty other things off your awesome list there, so i will do up a full list and pm it to you..
thanks again for your help brother.. :)
Hey could u send me a price and if in stock for s14 series 1 front hubs and bearings.?
Cheers phil
price on z32 afm to 5084 adelaide and are you able to get the plugs to suit??
cheers
Forgot to ask this too Taark...
20651-RS230 NISMO HARD RUBBER EXHAUST HANGER
Can you get these and how much?
Cheers,
Andy
Can you guys get Genuine Nissan O2 Sensors for RB20DE non turbo ones?
cheers Kane
hey mate im after rocker cover gasket for my s14 sr20det vvt engine, how much sent to moorabbin, melbourne 3189
price and availability on nismo rb25det engine and gearbox mounts.
thanks
Can u get nismo fpr for sr20 cheap ?
price for 2 nismo clutch pivots deliverd to Melbourne
Edited by SpecRS15
BTW - You spell lightning like this - LIGHTNING !!
NOT LIGHTENING
Hi Tark
Are you able to source:
- Rubber door seal
- Rubber window seal
For both driver and passenger sides to suit a s13 coupe??
plus delivery to 3550, vic
Edited by S15Roc
Hello taark,
Am after a shipped price on a fat o2 sensor.
To 2556 nsw.
Max
Mate,
I am after a price on 20 wheel studs (~15mm longer than std) and some D1 style nuts? Price and availability if you have em please.
Thanks
hi there, just wondering what is needed for a major service on an s15 sr20det like timing chain, water pump ect ect... also pricing to 5084 adelaide
thanks
Hey man I'm after a RB20DET Gearbox filler plug and drain plug.
Stock afm to suit my 97 model type x ??? Price and postage time ?
Also price on z32 afm please
Price on nismo fuel presure reg too please
Hi Taark,
Just wondering if you have the S13 sr20det flywheels bolts in stock yet? im only after 3
Cheers, Tim
Just wondering if you can get the bolts to hold in the coil packs for S13 SR20?
Do you still have any p12 rocker covers in stock?
Guest
This topic is now closed to further replies.
