gulrez
180 Type X 292rwkw 98 OCTANE street + track car
292kw on 98 octane
Yeah sure it's only got wheels
Luckly I didn't go high mount on your setup
When's the e85 dual map coming ?
I spot a furry friend at the back lol!
Wasn't near uni I assume....
haha yeah my missus got me that dog lol
nah it was on the way to join the m5 domestic airport way...
292kw on 98 octane
e85 man deffo o nthe cards all about the moeny atm to be honest...as it is its looking like mid year around june julyish
Edited by gulrez
plumb your screamer pipe back into the exhaust system
it can be removed to give u the option to go back to a atmospheric venting screamer pipe
u want the merge to be as far from the turbo as possible BUT it also has to me merged before the catalytic converter for it to still be a legal exhaust system
note the angle merge of the screamer pipe
Hey I saw this at the interclub sprint at EC last Sunday 16/9 North Circuit, goes well.
Apparently the car has seen a couple of track days since being sold months ago now...he has moved over to the dark side of Mitsubishi 4WD grip....
I seen it at eastern creek the other week
Does anyone know what Time it runs?
didnt see it run as I was driving
Ran a best of 1.17.03 on the North Circuit only 2 laps but was in the top half of a field of 90, 1:56.4 standard circuit a few months back also top half of a field of 120. I was running both these sprints and way off the pace :blush:
Car has been sold and new owner sent me these pictures
Still goin strong
OVER A YEAR NOW
There's so much more work I wanted to do to this car
Hope I see it again
spoke with the new owner of the car today
its still going strong ! not a single problem what so ever
still running on 98 octane and still street driven
Is the new owner on the forum and updating this thread?
His not on the forum but he sends me updates and I update for him
I haven't done much more work to the car other then welding a harness bar in between his strut tower
Would love to see this car with a good set of coil overs and running on e85
North Circuit
best lap time of 1.12.4
who would of thought this engine bay could make 327kw with only 25psi worth of boost
chea said it has a lot more left in it as its only on 25psi, didnt want to run to much boost because of the standard head bolts he predicts 350kw will be made at 30psi and that will max out the turbo
its on a very safe tune
292kw on 22psi using 98 octane
327kw on 25psi using E85
I remembered following this way back. I'm still suprise the standard 5 speed is still goong strong with that amount of power.
Gearbox has shat itself
Was it a std 5 speed box?
Yes
Hey kemp did you use a .64 rear housing or .86 for the turbo on this car ?
Just want to know if a .64ar will be restrictive at 300rwkw in t2
I bet those BC cams, springs retainers etc made all the difference.
its a T2 .63 externally gated housing which i modified to suit a waste gate
the right combo of parts working well with each other
Was it one of those tial housing which are basically a t3 .63 but the t3 flange swapped for a t2 and a port for external gate ?
Cause t3 .63 is similar size to t2 .86
You know of anyone who had made decent power over 280kw with the t2 .64 int gate or am I better off using the .86
Aren't those precision turbos t2 .64 the 5128 and 5130 cause I've got both housings but want to know which one to use before I put it together
Thanks
Thanks
no its a garret housing BUT its basically a T2 housing which has the exact same flow of a T3 style housing
pretty much a T3 .63 housing but with a T2 flange
