neil_se
Neil's FD3S Sprint Car
I'm back in an import after about 2 years away, keen to do some sprints and track days. I've picked up an S14 with lots of engine mods, it just needs suspension work. Here's a copy/paste from the ad, i bought it without the wheels.
1997 200sx S14A sports
95,000kms
5 speed manual
GKtech transmission springs
GKtech billet gearknob
Exedy heavy duty clutch
Nismo 1.5way diff with 4.36 ratio and 5 bolt shafts
Satin black wrap
Vertex bodykit
C-West dual blade wing
Clear indicators
BLITS - ADR approved vented fibreglass bonnet
Bride Vios 3 driver's seat
Forged engine:- Chemical clean, block hone, crack testing, etc.
40thou' Overbore
ACL Hyperlite Forged 87mm Pistons
Eagle Forged Rods
Balanced Crank
ACL racing series head gasket
Factory Nissan gaskets for everything else
All brand new Nissan parts for rest of completion (valve stem seals, main & rear seals etc)
ACL Race series bearings throughout
Greddy Alloy Sump (1L larger + with baffles and traps)
Gates Micro V belts
SplitFire Ignition Coils
Nismo Engine and gearbox mounts
Nismo Thermostat
Turbo Smart FPR
Sard 850cc Injectors
Custom Billet Fuel rail
Aeromotive Stealth 340 Intank fuel pump
Custom intercooler and piping
Custom 3" exhaust with magnaflow muffler
Aftermarket Aluminium Radiator
High Flow Cat
Pod Filter
C.E.S. Double dump pipe w/ HPC Ceramakrome Coating
3mm stainless exhaust manifold with bracing for turbo flange w/ Black Ceramic HPC coating
H.K.S. GT-RS Turbocharger Kit
Custom braided stainless steel turbo water & oil lines
H.K.S. Step 2 - 264' intake/exhaust camshafts
O.S. Giken intake/exhaust adjustable cam gears
Ported and polished s14 head, with VCT removed, Timing run in s13 style.
Apexi' Power FC Computer w/Hand controller
Apexi' AVC-R Black Series Boost Controller
Z32 AFM w/tomei plug and wiring
Tomei Rocker Arm Stoppers
GKtech eccentric throttle wheel
Ohlins PCV 8/6kg Coilovers
Enkei RPF01 17x9+22 Wheels
Nitto NT01 255/40/17 Tyres
Dba Front rotors
QFM AR1M Pads
GKtech master cylinder stopper
GKtech subframe risers
Whiteline adjustable swaybars
GKtech rear traction rods
Neotech RUCAs
Neotech rear toe arms
Neotech front castor rods
Front and rear strut braces
GKtech wheel studs
GKtech wheel nuts
Tuned on E85 - 260rwkw@15psi, 280rwkw@19psi
Original Pic
Now
First thing I've done is pick up an S15 HLSD that should be better for the street and the track until I can afford a 1.5way. I need to get some 4.1 or 4.3 diff gears before I install it though.
ENGINE MODS:
The car has some airflow problems that's holding the power back. It's still got the stock intake pipe that doesn't handle high airflow well so I've ordered an Apexi style alloy intake pipe and K&N filter. The intercooler piping is a bit of a mix and fairly restrictive so I've order a full set of new pipes, I just need a generic 600x300x75 cooler to suit as well.
I think these mods will free up the engine to reach the potential of the turbo, hopefully 240-250rwkw at 1.3-1.4bar.
SUSPENSION:
The suspension is fairly basic with just some HSD coilovers. I've ordered some rear camber arms and front caster rods to help with alignment. Next will be Whiteline swaybars and I'd like to soften up the springs as well to 7/5 or 6/4.
WHEELS & TYRES:
I'm on borrowed wheels at the moment so I'm pricing up a set of Enkei RPF1s and Nitto NT-01 tyres, 255/40/17 all round. I don't really want to have 2 sets of wheels so I'll see how much street driving I end up doing.
Good stuff mate.
Have done well by buying a pretty damn good car to begin with. With the extra mods your doing, it should be a really good performing track and street car.
Along with the stuff your doing, get yourself a race seat, harness, fire extinguisher and finally a run on the dyno to check everything out and you'll be set.
Cheers, I'm stoked with the car. It's got a Recaro drivers seat but I haven't tried it in an optimum seat position with a helmet on yet. Good reminder about the extinguisher, I'm sure I've got the one from my last car around somewhere still.
I paid for the wheels & tyres last night.
WOW now theres a name i havent seen in a while! Good to hear you're back kicking it
My control arms arrived today, they look very nicely crafted compared to the usual cheap arms.
Ordered F&R Whiteline adjustable swaybars today, that's most of the suspension sorted, I've just got to consider whether to change sprint rates down from 8/7.
Swaybars & intake pipe with K&N filter arrived today. The intake pipe will need some cleaning up inside.
And it begins.....
Awesome work, good to hear you back into a car for track duties.
QLD sprints/time attack look out!
Wheels and tyres are back, 5kg rear springs arrived today too.
aww man thats dope.. i'd love a clean street car like that, never seen that brand of rear arms but they look nice and thick
you better have some pics up tomorrow of those wheels fitted :) :) :)
Can't fit them yet, the rear end is apart until i fit the swaybar, arms and springs. The rear strut tops are a real pain to get to on the S14, and I'm nervous about getting in the car when its only on stands :blush:
All the arms, swaybars and springs are in. Test fitted the wheels and they sit perfect, just tucked inside the guards. Excuse the crappy iphone pics.
Next stage is to fit the new intercooler and piping, and intake pipe. I'm also going to wrap my car in a new colour, probably black.
mate the car is looking good, what offset are you running on those enkies they sit perfect mate
awesome man, looks porn now
Enkeis are 17x9+22 with 255/40/17 tyres. They don't look as wide as I expected but they fit perfect.
Mate i think they sit just right, any more than that is not good for a street/tracker, any scrubbin at all ?
I'm not sure yet, I backed it out of the driveway then straight back in to pull the front end off. I'll give the guards a bit of a love tap and there's clearance to the struts. It should be alright at full lock with the standard tie rods and ends, I don't need crazy drift lock.
Nice.. Awesome rim/tyre choice... Looks great and will be GRIPPY as hell!
The car is finally back together, it took a lot more work than I expected to fit the cooler piping. I took it to my shop today to start wrapping it in black.
man its coming together good, u painting it black hey? i wanna do my series one black too lol, what mods so far ?
sorry to bust your bubble but there is no such thing
i see it being advertised all the time ( for example GKtech )
but when u hack it up its not 3mm
cant even get steam pipe that thick in those diameter pipes
love the wheels~!!!!!!!!!!!!
