PH11PS
S13/RPS13 5-Stud Conversion and Brake Upgrade
Check out the original article here
IMG_1080.JPGFrom Phillipses blog
This is by far the greatest performance and safety mod that I've done to my car right next to coilover suspension struts. I was meaning to write this article up ages ago when I first got the conversion and upgrade done but CBS'd coz there was so much to it. But here we go, finally after coming across a fair deal of confusion online, I think it's about time I shared my experience. I hope that you find this an enlightening and helpful read. I've divided this article up into segments in order to keep each post a manageable size. There were lots of parts involved so I will be posting segments that can come under a different title separately.
Disclaimer:
This article isn't written as a guide or as a set of instructions to show you how to perform a 5-stud conversion or a brake upgrade, whatever you do with this article is done at your own discretion. This article is meant to be used as an informative piece that shows the experiences that I came across while performing a 5-stud conversion and brake upgrade for myself.
Intro:
The reason why I went for a 5 stud conversion was to support a brake upgrade I had in mind, and also to push and develop my ability to perform a significant mechanical task. I had always had a defeated mindset as a youngster when it came to mechanical ability, things started to change when I bought myself a Japanese import. This article was written by me as a technical memoir of the time that I as a 24 year old helpdesk decided to undertake a mechanical task that was beyond my means and ability. A 5-stud conversion, suspension upgrade, brake rebuild, and brake upgrade was carried out by me on my 1994 Nissan 180sx SR20DET with factory ABS. This segment will cover the front wheel 5 stud conversion and brake upgrade. Parts used were:
Front:
Set of front S14/15 hubs, knuckles, baffle plates and lower control arms
Custom machined sleeves to fit s14/15 knuckles to S13/RPS13 struts (14mm OD, 12mm ID)
Set of front R33 GTS-T calipers
Set of front RDA Slotted rotors to suit R33 GTS-T
Set of ADR approved custom made braided brake lines
IMG_0562.JPGFrom Phillipses blog
IMG_0678.JPGFrom Phillipses blog
IMG_0709.JPGFrom Phillipses blog
Rear
Set of rear R32 GTS-T hubs, baffle plates
Set of rear R32/R33 GTS-T calipers
Set of rear RDA slotted rotors to suit R32/R33 GTS-T
Set of R33 GTS-T handbrake cables
Eagle adaptor
IMG_0435.JPGFrom Phillipses blog
IMG_0449.JPGFrom Phillipses blog
1777.JPGFrom Phillipses blog
Other:
BM50 – Brake master cylinder from an R32 GTR with factory abs
Set of stock S15 rims with brand new Pirelli Pzero Nero's 225/40/16
IMG_0743.JPGFrom Phillipses blog
IMG_0707.JPGFrom Phillipses blog
Tools:
Full set of screw drivers
Full set of spanners
Full set of flare nut spanners
Full set of 1/4” and 1/2” drive sockets with wrenches and breaker bar
1/2” drive pneumatic rattle gun
Rubber head mallet
Steel hammer
8” 3 claw Gear Puller
2 Car stands
Hydraulic Jack
Couple of bricks or suitable tyre wedge stoppers
Background:
It's a good opportunity to upgrade brakes while doing a 5-stud conversion and vice versa. 5-stud conversions require you to remove the brake calipers and brake rotors in the process so the opportunity to change these parts makes itself available. Then there's the matter of having to drill out the 4 stud rotors to 5 stud if choosing to stay with the existing brakes which is illegal. By upgrading brakes, the rotors will also need to be replaced meaning you can find a set of rotors already made suiting the 5 stud configuration. I chose to go for R33 GTS-T front and R32 GTS-T rear brakes with RDA slotted rotors front and rear. These rotors are factory drilled to 5 stud so fit the new setup perfectly. Also remember that upgrading your brakes may create issues with clearance. In cases where rims do not clear brake calipers, spacers may need to be employed temporarily until replacement rims can be sourced.
I performed my conversion and upgrade in my own backyard with little more than hand tools and a rattle gun. I'm not a mechanic, I haven't been playing with cars all my life, I only really became genuinely interested in playing with cars at the age of about 22 when I bought my first car. I must say that though that this conversion and upgrade wasn't easy... I spent a lot of time doing research and there wasn't really a whole lot out there, some of the process was trial and error, and I work full time so was working on the car during nights and some Saturday's. It wasn't an extremely difficult task (it's not rocket science) but it does take a keen spirit, patience, and a fair bit of elbow grease.
5-Stud Conversion-
5 stud conversions have been popular amongst s13 owners to enable fitment of a wider variety of rims. 4 stud rims in good sizes, offsets and design are generally pretty hard to come by, by going 5 stud, you make available to you a much larger range of rims in a wider range of sizes, offsets and design. Whether it be completely for aesthetics, for the purpose of clearing brake calipers after an upgrade, or to modify your vehicle to fit those elusive rims that you've had your eye and heart set on, 5 stud conversions are definitely becoming popular with the 4 stud equipped community. They are famous for Nissan s13's and Honda Civics and Integras. There are quite a few aftermarket options for replacement hubs that will convert 4 studded Silvia's to 5 stud, these require pressing of the aftermarket hub onto the bearing. I chose to go with Stock Nissan parts to ensure quality, reliability and compatability. I've heard mixed reports on aftermarket parts and concluded not to take that path due to safety issues, but also because I found the Nissan OEM parts were locally and readily available. There is a lot of confusion to what will and won't work with 5-stud conversions on S13/RPS13's. There are so many options that are possible, below is a rough guide of what I learned during my research about the most commonly chosen options.
Fronts
S14/S15 hubs pressed into the S13/RPS13 bearings –
2993P2040502.JPGFrom Phillipses blog
Requires to have your old 4 stud hubs pressed out, and new hubs pressed in. Will retain ABS if the car is currently equipped with ABS. Nowadays you won't find too many hubs selling detached from the bearing. No change to track, toe, castor or camber. Stock uprights and control arms are retained. This method will require you to use a rattle gun to unbolt the hub from the upright (It's darn impossible to remove the bolts other wise) and take the hub/bearing assembly shop to be pressed out and have the 5 stud hub pressed in. I'm a little biased towards OEM parts as you can trust them to last the distance.
Aftermarket 5-stud hubs pressed into the S13/RPS13 bearings –
1778.JPGFrom Phillipses blog
Works much like pressing Nissan OEM 5 stud hubs into your existing bearings, just make sure that the hubs will fit the bearings as I've heard of a case where someone had to get different bearings made to fit the hubs into the uprights which is not cheap. The manufacturing quality and standard of the hub also varies as is the installation process (some hubs kits come with detached screw threads that require loctite), make sure you do your homework if choosing this path. This is a common and popular approach to 5-stud conversions, and there are many examples of high quality installs using aftermarket hubs. Must check to whether or not ABS is retained in ABS equipped cars. This method will also not make any changes to track, toe, castor or camber.
S14/15 OEM hubs and bearings assembly (generally comes attached to uprights with LCA's) –
From what I've found, the most common of all, and the path that I chose. OEM products mean you know that they work as they are used on production cars, I bought my hubs already bolted into the s14/15 upright assembly complete with LCA's, rotors and calipers. All I had to do was bolt the assembly into my rails and struts with the help of some custom sleeves. The custom sleeves are required to attach the uprights to the stut mounting holes. Reason being, S14/15 upright mounting holes have a 14mm diameter, whereas S13/RPS13 strut mounting holes are 12mm in Diameter, these sleeves ensure that there is no free play in the uprights once mounted onto the strut. Note that using S14/15 uprights and LCA's although convenient will increase your track by a total of 10mm over both front wheels, which will mean some horrible toe out after install. This means that you will need a major wheel alignment immediately after the install and your car will handle differently afterwards (less understeer). Some people may find this undesirable. In the case of having S14/15 uprights without LCA's, you can opt to have new ball joins (R33 GTS-T ball joins to be exact) pressed into your existing LCA's to fit the S14/15 LCA's as they are a different size. I've heard from a few knowledged people and a performance shop employee that this method can come across some reliability issues, and it is best to stick with the S14/15 LCA's despite the slight increase in track.
Rears
S14/S15 rear hubs –
hubs1rf1.jpgFrom Phillipses blog
Generally, these are sold with the bearing unit attached. I've yet to see rear hubs sold without bearings. The hubs are a direct replacement with the S13/RPS13 units thus do not affect toe, or camber.
R32 GTS-T rear hubs –
IMG_0439.JPGFrom Phillipses blog
Pretty much exactly the same as S14/15 rear hubs, these are the ones I've got in my 180sx.
R33 GTS-T rear hubs –
DSCF1679_.jpgFrom Phillipses blog
I've not had a play with these myself, apparently they're the same as S14/15 and R32GTS-T but I remember hearing a while ago that the number of splines for the half shafts are different to the S13... I've never been able to confirm but I've also come across people recommending R33 GTS-T hubs for 5-stud conversions.
Aftermarket rear hubs –
RHub_bearing.jpgFrom Phillipses blog
Same deal with aftermarket front hubs, see Aftermarket 5-stud hubs pressed into the S13/RPS13 bearings above
Brake Upgrade-
The brake upgrade is also a very popular modification performed on S13/RPS13 Silvia's. The stock brakes on an SR20DET S13/RPS13 are pretty crap to say the least. They are a single pot setup both for both front and rear calipers. The rear calipers have combined hydraulic and cable utility so that the caliper actions to both foot pedal and handbrake lever. It is common for people to upgrade the front calipers of an S13/RPS13 yet leave the stock rear caliper. This is partly due to the fact that upgrading the rear calipers requires extensive work in implementing a drum handbrake assembly. I chose again to go with Nissan OEM parts as they are cheap, readily available, work remarkably well, are easily rebuildable and are a direct bolt on. I upgraded both front and rear calipers including implementing the drum handbrake assembly. This allows maintaining the balance of brake bias between the front and rear calipers for a more controlled and predictable braking behaviour. There are heaps of options on what is available to s13's as brake upgrades, some of these bolt on, some of these don't. Remember that when calipers are upgraded, rotors must also be upgraded accordingly as well as the Brake Master Cylinder to maintain brake pedal firmness and effectiveness. Below is a list of viable options throughout the Nissan OEM range and the impressions I made of them when I was doing my research.
Fronts
S14/15 –
IMG_0669.JPGFrom Phillipses blog
One of the most popular choices if not the most popular choice of upgrade for S13/RPS13. These are 4 pot callipers and are made of Iron. They are very similar to the front calipers found on R32 GTS-T and 300ZX only they are heavier being cast of iron and not alloy. Rotor size is 280mm diameter x 30mm ventilated thickness. Popular because they are relatively inexpensive, quite common and have great stopping power. They are quite simple to rebuild and look great.
R32 GTS-T –
R32_Z32_front_aluminum_4_piston_calipers.JPGFrom Phillipses blog
Another very popular choice of upgrade for S13/RPS13. Similar to the S14/15 calipers, they too are 4 pot only they are made from alloy which make them significantly lighter which reduces unsprung weight. Rotor sizes are the same as S15 at 280mm diameter X 30mm ventilated thickness. I found that R32 GTS-T are still quite commonly available, and are great value. Again simple to rebuild.
300ZX Z32 –
DSC02954.jpgFrom Phillipses blog
Built pretty much identical to the R32 GTS-T calipers, the Z32 calipers can be identified by their heat sink cooling fins. Again made from alloy and sharing the same rotor sizes as the S14/15 and R32 GTS-T measuring in at 280mm diameter x 30mm ventilated thickness. Simple to rebuild.
R33 GTS-T –
IMG_0674.JPGFrom Phillipses blog
Moving up in size from the S14/15, R32 GTS-T and Z32 stands the R33 GTS-T calipers. Made from alloy, but sporting larger pistons means more even stopping surface pressure, which means greater stopping force can be applied before locking up. These are the calipers I installed in my 180sx. Slightly more expensive than the calipers above and physically larger, the stopping force on these guys are immense. I rebuilt mine by myself and had them powdercoated, the whole process was relatively simple. The rotor sizes of increase slightly over the previous mentioned, being 296mm diameter x 30mm ventilated thickness.
R32 GTR –
1779.JPGFrom Phillipses blog
Having slightly thicker cross drilled rotors and again larger and deeper pistons over the previous mentioned brakes, the R32 GTR front brakes are very highly rated and have amazing stopping power. The cross drilled rotors eliminate excess weight and prevent brake pads from glazing. Some people claim that cross drilled rotors improve ventilations or cooling, I was always under the assumption that the more surface are there was to cool, the higher the rate of cooling. These rotors measure in at 296mm diameter x 32mm ventilated thickness. The caliper is made of alloy and is slightly larger than the R33 GTS-T caliper due to the larger, and deeper pistons.
R32 GTR VspecII/R33 GTR Brembo –
11122008284.jpgFrom Phillipses blog
The highest performing bolt on Nissan OEM replacement one can hope for. These calipers are 4 piston black ceramic coated with gold print. The rotors measure in at a whopping 324mm diameter x 30mm ventilated thickness. Significantly more expensive then the Sumitomo produced calipers (the non-brembo Silvia, Skyline and Z calipers), and much less commonly found for sale, these are reserved for those running big numbers requiring the monstrous stopping power that these brakes offer. The rotors vary from slotted and cross-drilled all finished with anodised alloy hats.
R34GTR/Z33 (350Z) –
brembo2.jpgFrom Phillipses blogFrom Phillipses blog
Same specs as the R32 GTTR VspecII and R33 GTR Brembo's, only these are gold ceramic coated with red print, and the mounting holes are slightly different meaning that adaptor plates will need to be made up in order to retrofit these to Silvia's, pre R34 Skyline's, and pre Z33's.
Rears
S13/14/15 –
IMG_0714.JPGFrom Phillipses blogFrom Phillipses blog
The S13/14/15 rear calipers are the same as the ones found factory on the S13/RPS13, thus isn't really an upgrade. This unit is a dual action single piston sliding unit. That is, it has both a hydraulic feed that actions the caliper as well as a cable system that is attached to the handbrake to lock the caliper when tightened. Good pads will dramatically increase the effectiveness of braking with this caliper. 256mm diameter x 9mm thickness are the dimensions of this rotor. These rotors are solid and are not ventilated.
R32 GTS-T/R33 GTS-T/R34 GTS-T/Z32 –
IMG_0676.JPGFrom Phillipses blogFrom Phillipses blog
The rear brake calipers in this range are pretty much one in the same, they are a twin piston unit meaning more effective and even braking over a broader surface area which in turn translates to a more controlled braking experience. The calipers are controlled completely by hydraulic feed meaning foot brake pedal or hydraulic hand brake if one is installed. The handbrake is connected to a drum handbrake assembly located on the baffle plate. Drum handbrakes lock stronger than caliper handbrakes. These rotors unlike the S13/14/15 rotors are ventilated, the dimensions are 297mm diameter x 18mm thickness. The centre hats of these rotors are also significantly higher and larger than that of S13/14/15's as they house the drum handbrake assembly.
Installation Process:
Fronts
Upgrading seems simple now that I look at it in hindsight, but it was almost torturous while I was there. I made sure to take my time and not put myself in a place where I could risk getting badly hurt or damaging my car, parts or tools.
IMG_0546.JPGFrom Phillipses blog
IMG_0541.JPGFrom Phillipses blog
Begin first by chocking the rear wheels with bricks and jacking the front end up with a good jack underneath the crossmember, using car stands, settle the front end onto the stands making contact with the rails and proceed on to remove both wheels. Then continue by removing the old caliper off the upright by unbolting it from behind. There's two bolts holding it very firmly in place. WD40 or similar penetrating solvent works wonders.
IMG_0544_instr.JPGFrom Phillipses blog
Using a flare nut spanner, disconnect the brake hose at where it meets the solid brake line at the chassis point indicated above in yellow. Remove the brake hose clip indicated in pink by pulling the clip away from the strut using a pair of pliers. After the clip comes off the caliper should be free, take caliper and place it aside. The rotor can then be removed from the hub by tapping the hat of the rotor with a steel hammer to break the bind of the rust and grit caught between the rotor and hub. If the rotor seems really stuck, you can screw an appropriate sized bolt into the screw holes found on the hat of the rotor, this will pry the rotor off the hub, be sure to use the correct size screw, you don't want the screw threading, becoming stuck or snapping while doing this.
IMG_0583_instr.JPGFrom Phillipses blog
IMG_0580_instr.JPGFrom Phillipses blog
If your car is equipped with ABS like mine, you will be required to disconnect the ABS sensor, this is identified by the thick insulating wire that leads from the chassis much like the brake line and joins the sensor into the upright and is screwed into place by a 10mm hex screw. This may take a bit of fidgeting as the sensor is pressed in tight, be patient and keep working at it, it'll come out. I worked the sensor out just enough to wedfge a flathead screwdriver in between the sensor and upright and gently but firmly pried the unit out that way.
IMG_0542_instr.JPGFrom Phillipses blog
After the ABS sensor has come out, proceed to unbolt the control arms from the assembly marked above in yellow. The steering rack balljoint is held in by a cotter pin so make sure to undo that before undoing the nut. Even after the nut is undone, the balljoint might not fall out freely so you may need to tap the end of the ball joint with a hammer, remember to place a nut over the first few threads so you'll be hammering tht nut, not the balljoint to avoid damaging the thread. The castor rods and sway bars undo quite simply from nuts tightened to the bottom side. After the control arms are free, free upright from the strut by undoing the two bolts highlighted in pink, using an the rattle gun. Make sure you have a crate or some kind of support under the assembly to support it after it is unbolted as it's quite heavy. Next unbolt the lower control arm from the chassis highlighted in green, I couldn't get the rattle gun in there so I used a breaker bar instead. Once the lower control arm is free, remove the assembly and put it aside.
IMG_0564_instr.JPGFrom Phillipses blog
At this point insert the custom made sleeves into the S14/15 bolt holes. The reason for these is to close in the 14mm holes to 12mm as S13's use a 12mm diameter bolt whereas S14/15's use a 14mm diameter bolt to secure the uprights to the strut, alternatively, you can drill out the 12mm holes in your struts to 14mm. Having done this, use the reverse of the previous steps, reassemble the S14/15 upright assembly to the chassis, strut and control arms, also remembering to reconnect the ABS sensor. In my case I didn't connect the shown caliper as I had a set of R33 calipers planned for install.
IMG_0585_instr.JPGFrom Phillipses blog
For those who are planning to go any R33 GTS-T caliper or larger, you will need to cut a set of grooves into the dish of the bash plate and bend the dish out to make a flat pan as shown above. This is so that the rotors can fit without fouling on the bash plate. Use a hacksaw or suitable cutting tool to cut into the wall of the plate to at least the depth of the pan, from there, use pliers to bend the plate out. Fit the larger rotor and ensure that there is enough room to avoid fouling.
IMG_0684.JPGFrom Phillipses blog
At this point, install your new rotor onto the hub, fit the caliper over the rotor and bolt it securely into the upright. Remember to use the right caliper, LHS for passenger side and RHS for drivers side. The nipple must always face the bottom. Connect the brake hose mid section to the strut using the brake hose clips, and connect the ends of the hose to the caliper and chassis hardline.
IMG_1082.JPGFrom Phillipses blog
Next, line up your 5 stud rims and tighten them up... Repeat the process for the other side... Lower the car and voila! Time to move onto the rears. Do NOT drive the car as there is now air in the brake lines and the car will not be able to brake effectively.
Rears
The rears are a fair bit more difficult to install than the fronts... This is mainly thanks to the complex drum handbrake assembly. What we are trying to achieve is a retrofit of the skyline drum handbrake assembly and 5 stud hub onto the S13 uprights.
IMG_0385_instr.JPGFrom Phillipses blog
Start off by chocking the front wheels with bricks and jacking the rear end up with a good jack from the diff, remember to use car stands underneath the rails to hold the car up while working. Having done that, remove the wheels.
IMG_0225.JPGFrom Phillipses blog
Using a 10mm long barrel socket and wrench/driver, loosen the handbrake cable. This is done from the inside cabin, the handbrake tightening nut is located on the handbrake lever. Pull the handbrake lever up until you spot the circular cutout on the base of the handbrake lever cover highlighted above in yellow, the handbrake tightening nut is located in there, place the long barrel socket into the cutout and loosen the nut until there if there is no more tension in the handbrake when engaging or disengaging, leave the handbrake disengaged. Having loosened the handbrake, get underneath the car and place yourself underneath the tailshaft. Look up to the floorplan directly above the tailshaft and you will notice the handbrake cables that connect the calipers to a T-piece that looks like the image below.
IMG_0451.JPGFrom Phillipses blog
subframe.JPGFrom Phillipses blog
Unscrew the handbrake cables from the chassis using a 10mm socket and driver, then detach handbrake cables from the T piece by rotating each cable until it fits through the notch allowing the locking head to disengage. Do not cut the steel wire as the above pic indicates. There are also two screws that secure the handbrake cables, they are indicated by the purple X's above, be sure to unscrew these also.
IMG_0388_instr.JPGFrom Phillipses blog
The caliper can now be unbolted from the upright via the 2 bolts that hold it in place.
Disconnect the the brake hose by using a flare nut spanner to undo the flare nut found on the opposite side of the bracket marked above in yellow. Once this is done, remove the caliper and place it aside. The rotor can then be removed, if the rotor seems stuck onto the hub, try tapping the hat gently with a hammer, or alternatively you can screw in an appropriate sized screw into the screwhole located on the hat which will pry the rotor off the hub. Be sure to use the correct size screw, you don't want the screw threading, becoming stuck or snapping while doing this.
Undo the cottor pin and bearing lock nut cover highlighted above in pink. This will reveal the bearing lock nut which must also be removed. There's a few ways to take care of this nut if it's really siezed. I found that a rattle gun works best however if using a breaker bar, you may find that the axle will rotate under the force of the breaker bar even if the car is in gear. In this case, remove the centre cap from the wheel, fix the wheel onto the hub, drop the car, place the socket into the wheel's centre cap hole and try breaking the nut like this. I've heard of some cases where the nut is so siezed that people will even lean the breaker bar against the ground, start the car up and drive along using the weight of the car to break the nut. This sounds clever enough however I've never had to do it myself. In this case the car will need to move forward to break the driver side nut and in move in reverse to break the passenger side nut. Remember, WD40 and similar penetrants work wonders.
01.jpgFrom Phillipses blog
Next, unbolt the half shaft from the diff end, this is highlighted above in yellow. This will require getting under the diff and using 2 14mm spanners. There are 2 variants of half shaft in s13's the 5 bolt and the 6 bolt, however they use the same sized nuts and bolts. Once the bolts are removed, move the shaft so that it is no longer pressing up against the diff.
IMG_0474_instr.JPGFrom Phillipses blog
Slide the half shaft out of the hub assembly. This is often easier said than done as quite often due to corrosion, wear and tear, grit and grime the shaft finds itself quite happily seized, use WD40 generously and if need be screw the bearing lock nut a few threads deep onto the shaft and tap the nut with a soft hammer. Alternatively, what I did was use an 8" 3 claw gear puller which made the job a cinch.
IMG_0434_instr.JPGFrom Phillipses blog
Now it's time to remove the upright and hub assembly. This is done by unbolting all the connection points that hold the upright in place. Place a support unerneath the lower control arm and proceed to unbolt the uprights from the traction, control, toe, strut and lower control arms. These are indicated by the green highlights above. Please note that in the above image, the strut is missing however it serves as one connection point. The lower control arm connection point is a balljoint type and as a result is fixed on by a nut and cotter pin, the cotter pin must be removed before the nut can be undone. The balljoint may be stuck tight onto the upright, in that case, screw the nut onto the balljoint thread a few threads deep and tap the nut with a soft head hammer. When the connection points are all disconnected, take the upright and hub assembly, and place it on a work area like below.
IMG_0442_instr.JPGFrom Phillipses blog
IMG_0441_instr.JPGFrom Phillipses blog
IMG_0444_instr.JPGFrom Phillipses blog
IMG_0445_instr.JPGFrom Phillipses blog
Turn the assembly so that the upright is facing up, use a rattle gun to undo the 4 bolts highlighted above in yellow, these bolts are tight and due to being on a rotatable hub assembly would not be removed any other way. Once the bolts are removed, separate the assembly as shown above.
IMG_0437_instr.JPGFrom Phillipses blog
IMG_0440_instr.JPGFrom Phillipses blog
Now it's time to do the same but with the Skyline unit. Note how this unit has the handbrake cable connected connected into the baffle plate whereas the s13 handbrake cable was connected to the caliper? This is the defining difference between the handbrake function between the two classes. Also note that there is one extra nut on the skyline unit that will need to be removed, this is highlighted above in yellow. Once the nuts and bolts have been removed, separate the assembly as shown above.
IMG_0450.JPGFrom Phillipses blog
IMG_0439_instr.JPGFrom Phillipses blog
Now it's time to swap the handbrake cables. The reason why the R32 handbrake cable must be swapped with the R33 unit is due to the design of the terminals. The R32 unit will not connect up to the S13 T-piece however, the R33 terminal will. Note the difference between the terminals on the two units above. The first terminal is the R32 and the second terminal is the R33. Start by first undoing the screw on the back of the unit that holds the handbrake cable to the baffle plate, then using the above image as reference, use a flat head screwdriver to rotate the screws highleted in yello 90 degrees, they are spring preloaded and will pop out. Next unclip the 2 spring hooks from the anchor highlighted in pink, with these items unclipped, the drum brake unit should slip out with a bit of fidgeting, however will still be connected to the handbrake cable. Note the red arrow, this indicates the handbrake cable anchor point, simply unclip the R32 handbrake from this anchor point and replace with the R33 handbrake cable. After the cable has been replaced, piece back the drum handbrake by going through the last steps in reverse
NOTE: Use the RHS R33 cable for the LHS assembly and vice versa theLHS R33 cable for the RHS assembly. This will be explained.
IMG_0447.JPGFrom Phillipses blog
Next, combine the R32 baffle plate (with R33 handbrake cable), the R32 5-stud hub, and the S13 upright to make a Frankenstein unit. Note that the hole on the s13 upright that the r32 baffle plate anchor fits through will most probably be filled with grime, rust and grit over the years making it highly unlikey for the anchor to be able to fit through, a dremel tool works wonders here, I made do with a round file and some course sandpaper. Try line up all the holes before inserting the screws, it makes it alot easier doing this now before anything get's bolted back together. When that's done, bolt it all back up TIGHT. I used the rattle gun on max setting and kept at it as I knew that this will never be coming apart again.
IMG_0448_instr.JPGFrom Phillipses blog
Bolt the half shaft back onto the diff while the assembly is out, having the assembly out will make this alot easier. Bolt the assembly lower control arm supporting the control arm with a crate or jack. Remember to place the cotter pin back in place. This is a good opportunity to take some dry steel wool to the half shaft and hub splines to get clean the surface and clear up any corrosion that may have built up. Feed the half shaft through the hub, then bolt up the traction, camber, toe and strut arm connection points. Feed the handbrake cable through the rear subframe and just let it sit there for now.
IMG_0679.JPGFrom Phillipses blog
Install the new rotor onto the hub,observe how the rotor fits, is it clearing the drum handbrake assembly? Is it fouling against it? Remove the rotor and using a flat head screw driver, adjust the spline circled in green above to increase/decrease the preset of the drum handbrake. Adjust so that the rotor hat will fit snugly over the drum handbrake with a bit of fidgeting, then loosen it 2 more clicks. Put the rotor back on. Fit the Skyline caliper over the rotor, bolting it tightly into place. Connect the brake hoses between the caliper and brake hardline located on the bracket where the S13 hose used to connect. Screw the bearing lock nut tightly back into place, insert the lock nut cover and secure by threading a cotter pin through the hole in the spline. The 5 stud rims can be bolted back on at this point
NOTE: Use the left caliper for the passenger side and right caliper for the driver side, the bleed nipple should be at the top.
Now onto feeding the handbrake cables to connect onto the T-piece. The above image explains why the LHS handbrake cable must be used on the RHS and vice versa. The R33 handbrake cables have a little more length to them than the S13 handbrake cables, thus if the lines were not criss-crossed as shown, there would be too much slack in the line which will cause the line to foul against the tail shaft and/or the rims. The lines need to be fixed where the pink X's indicate, the brackets on the R33 lines will be a little off so will need to be loosened with pliars and relocated so as to have an even amount of slack along the line.
Affix the eagle adaptor with 2 screws in the screw holes underneath the car along the floor plan above the tailshaft where the previous s13 handbrake cables used to be fixed near the T-piece. That is, where the s13 cables used to be screwed into, screw the eagle adaptor instead. The two bottom holes should line up perfectly. The other holes should face towards the front of the car. Note that the nuts on the eagle adaptor should face upwards towards the chassis, thus what you see from underneath should be completely flat. Next, screw the R33 handbrake cables to the eagle adapator remembering the lines need to criss cross after the rear subframe. After this has been done, check to make sure that the slack along the line is even and not fouling against any moving part, in particular the tailshaft, half shafts, rims, rotors or calipers.
Tighten the handbrake up using a 10mm long barrel socket and driver, the tightening nut is located on the handbrake cable and is accessed via the cutout indicated above in yellow. The handbrake should be tightened until it feels as it did with the old S13 setup or set as desired.
IMG_1081.JPGFrom Phillipses blog
Lower the car and voila! Time to move onto the Brake Master Cylinder. Do NOT drive the car as there is now air in the brake lines and the car will not be able to brake effectively.
Brake Master Cylinder (BMC)
The purpose of upgrading the BMC is to increase the pedal firmness under braking after a brake upgrade. Without upgrading the BMC after a significant brake upgrade, it is possible for the brake pedal to to hit the floor before 100% braking efficiency is acheived. ABS model BMC's must be used with ABS equipped vehicles likewise non ABS model BMC's must be used with car's not equipped with ABS. Note that my car had come equipped with a BM50 which is the same model as the R32GTR ABS model, meaning I didn't need to upgrade. If this is your case, then you also can retain your BMC.
IMG_0593_instr.JPGFrom Phillipses blog
Start by opening your bonnet, the BMC is located on the firewall where the steering wheel is located.
IMG_0744_instr.JPGFrom Phillipses blog
Unclip the power cable highlighted in green, and using a flare nut spanner, unscrew the flare nuts from the threads marked in yellow. Be careful as flare nuts are very easy to round off. Unbolt the BMC from the firewall via the bolts that yu will find where the blue markers are. Reverse the process to install the new BMC.
Flush/Bleed Your Brakes
This is a very important step. Modifying your brake system has caused air to become trapped in the lines. Unlike brake fluid, air is highly compressible so drastically hinders your braking performance. Bleeding will cause all the air to exit a brake system, whereas a flush completely replaces the fluid in a system with new fluid. Flushing/Bleeding your brakes works best with 3 people. One to compress, and one to bleed, one to keep the BMC filled. Purchase the correct brake fluid, I purchased DOT4 and used 2 standard service sized bottles for a full flush and it was JUST enough. Do not use the wrong brake fluid as it may cause damage to your brake system which can lead to failure. Start from the caliper furthest from the BMC and work your way to the closest one. So for Silvia's and Skylines from Japan and Australia
(ie right hand drive), that would be rear passenger first, rear driver second, front passenger third, front driver fourth. Place a brick or similar spacer behind the brake pedal so it doesn't bottom out, brakes bottoming out is a big no-no as it destroys BMC's. Do not ever let the BMC run dry as this will suck air into the brake system defeating the purpose of flushing/bleeding the brakes. This takes a bit of team work and coordination as one person will call as he compresses the brake, and the second person will have to open the nipple during compression, but close it when the pedal is released. The third person must always make sure that the BMC is at full. This should continue until there are no bubbles in the fluid and when the new fluid starts to bleed. You can usually tell by the colour change.
Before you go out to test the new brakes
The wheel alignment is going to be crazily out due to all the major surgery, so see a wheel specialist right away and get a full wheel alignment.
The difference it makes
As I mentioned at the beginning of the article, the brake upgroad is by far the greatest performance and safety mod that I've done to my car right next to coilover suspension struts... After the wheel alignment, I noticed the difference right away... ABS works as normal but braking effectiveness has increased dramatically... Slamming on the window now propels me out of my seat like crazy. I've also got some fat wheels since starting this article taking advantage of the 5 stud conversion
  • Upvote 1
nice write up! should be a sticky!
yeah nice work, the wikipedia articles don't have any pictures shown so this article is a must for sticky!
Bout time Phillips lol :lol:
Geez, only if I had the patience and time to do a write up myself. Good job mate!
Moving forward, anyone posting a query regarding "5 stud upgrades" and the likes will be flamed hard ^_^
Cheers,
Andy
Nipple should be at the TOP.
^^ That it should.
SOMEONE PLEASE FOR THE LOVE OF GOD STICKY THIS !!!!!!
this should be compulsory reading for ALL new members, let alone a sticky.......it can be found in the tech articles section with patience though.
hey man, where you wrote about the R34 gtr front calipers, it was a a bit wrong.
they have a 14mm mounting bolt, so you just need to drill the knuckle holes out to 14mm and use shorter bolts
other than that they are a straight fit.
also a bump for the fact this should be stickied
Good job, im doin da same up upgrade just a bit stuck on da eagle plate im thinking of makin my own, once again top job ;)
here's the link to the current place to buy the eagle adapter plate for the handbrake cables
click here
Ive red that whole article countless times and still dont fully understand why the "Eagle Adapter" is necessary?...and the mounting points for the R33 skyline H/Brake cables in different spots or something?...
my understanding is that the 33 lines are slightly longer and the adaptor moves the connection point forther forward to compensate.
im doing the r33 gtst rear caliper conversion, i think iv been given the wrong skyline backing plates as they dont clear the vented discs (disc diameter is too big)
i cant justify buying the eagle adapter so will probably make my own, has anyone got measurements for such a bracket?
when selecting braided lines will i need to get them custom made or are they factory sizes for a particular skyline???
(im doing s14/15 4 pot front calipers)
thanks guys any help is appreciated
hey mate i tried the method of pressing s13 bearings into s15 hubs... that dnt work
When you actually have the r33 handbrake cables in your hand compared to the s13/14/15 cables you can then see the need for the "eagle adapter plate. Use this picture to make your own like I did, works a treat.
Hi guys,
awesome write up.
Im thinking of converting my 180sx to 5 stud but dont want to change the track or anything else.
If i get some s14/15 r32 rear hubs pressed onto my s13 bearings, will i still be able to use my standard 180 brake caliper and rotors? (with the rotors re-drilled of course)
Looks like a cheaper option than buying the hubs with arms and knuckles etc all attached... And doesnt f**k with the handbrake cables...
Thanks,
Chris
Thanks but that didnt help at all.
"The hubs are a direct replacement with the S13/RPS13 units thus do not affect toe, or camber."
Thats whats written in the writeup, and i would prefer to use oem parts instead of aftermarket.
I just want to know if i can use my standard 180 brakes with the 5 stud hubs?
yes you can run the stock brakes. and i mean that you can't just swap the front bearings.
cheapo 5 stud:
front:
s14/15 knuckles, hubs and balljoints. re-drill the rotors and use the s14/15 balljoints in the stock LCA. will need sleeves in the clevis to make it 12mm or drill out the struts to 14mm
rear:
s14/15 r32/33 rear hubs and re-drill rotors or run s14/15 rotors.
i know its an old post
but can you use s14 hubs and r33 drum handbrake setup together?
i see that he has said s14/15 are pretty much exactly the same as r32 but pretty much and exactly are 2 different description all together
i have a full s14 brake upgrade/5 stud conversion on my s13 and would make it easier if i could just use the backing plate and drum setup, calipers n discs off r33
You can use S14 hubs as even tho the hubs are pretty much the same as R32 they will fit. Just use the R33 backing plate.
With the rears, Can you just use s14 hubs with s13 bearings or do you need the bearings too?
Does anyone have a picture of what the sleeves look like? Also can someone tell me where to get them made up? Cheers
