[IB6UB9]
help with amp
hey people,my amp is currently displaying a code error of "E-3" meaning its a power surge.the amp is the alpine MRD-M500,is anyone has any idea what could be causing this can you please help me out.
Cheers Tuan
what are you running off of the amp? have you tried running a different speaker? if the speaker is stuffed it may cause this.
or could be a speaker wire grounding / (shorting) out.
or it could be that you have too many subs running off it. (ie running at 1ohm when it is only 2 ohm stable)
dunno? just some random suggestions to look at. might help?
also, chech the main power cable. i've seen a power cable short on chasis where it was fed through the firewall as no rubber grommet was used.
i am yet to try another sub,but i have turned the amp on without sub/speakers connected and the error code still comes up.i am only running 1 sub.
just a thought... are your positive/ground mixed up on your amp?... happened to me once, and this situation sounds familiar...
^^^nah man all wires are wierd up fine.Gonna test it with another amp and see if same problem
