Tylthidras
Garage clearout
NEW HIC translucent plastic weathershields suit s13: $50
NEW Half arch bolt on flares (same as MCM used on their dark green 180) :50
Adj castor rods (need studs that bolt it to LCA, otherwise in good nick, have modified rose joint caps + spacer to increase the angle for minimally extra wheel clearance on lock): $25
Universal 6 row Oil cooler + relocation kit: $50
cadence csb-104 sub/xenith xa 125.2 amp: $50
NEW SR20 coolant temp sensor: $10
NEW Password jdm bumper quick release kits x 4 (2 silver 2 black): $10 each
NEW Benen industries neo chrome tow hooks w/mounting bolts : $40 each
NEW Gktech v1 10mm axle spacers (pair) with bolts (5x1 bolt pattern): $25
NEW Gktech s13 handbrake cable extenders: $30
NEW Unknown brand rear braided & sleeved brake lines s13 : $50
NEW Qfm brake pads (db1170) suit r33 front calipers: $60
NEW Bendix CT pads (suit rear M35 stagea & 350Z)
NEW Sparco style pedals: $10
NEW Gktech billet aluminium solid gbox mount (s13/14/15/r32 gtst): $30
Gktech 5mm slip on spacers (multistud) $10
NEW Nice extended wheel studs x 10 (suit s13): $10
NEW Ultra racing c pillar brace suit 180sx: $100
DBA T3 slotted front rotors (suit r33 turbo). Seen not even half a day of use at a drift prac: $200
RDA dimpled and slotted rear rotors (suit M35 stagea). Trial fitted and run with car on stands for probably about 2/300 metres: $100
Can provide photos as necessary. Have no issues posting at buyers expense. Contact via PM or text (0431-622-600). Located southern suburbs Adelaide.
