200sxs14asr20det
HELP! S15 6speed manual wont go into any gear when car is cold
Hey guys I am in need of HELP PLEASE !
I have a stock 2001 200sx s15 6 speed manual, only mod is a hd clutch.
-When the car is cold I cant seem to put the car into any gear when the car is running after a cold start up,
-Only way I can get into a gear on cold start up is with the engine of I put it into 1st gear or reverse gear.
-Once the car is warm the car goes into all gears with no issues or no crunching.
-The only thing I can hear wrong is the input shaft bearing whine on idle, when you engage the clutch the whine stops = gearbox input shaft bearing
Does anyone know what can cause this issue where the car wont go into gear when cold?
any help would be much appreciated
Edited by 200sxs14asr20det
Could be low oil level, shitty old oil or wrong oil. Go get some decent oil and change it, dont overfill it like some people say to with the idea that extra oil makes it better. Just fill it to the level at the filler hole.
Spot on, drop the oil and give it something good.
