sump hitting sway bar issues 180sx rb25det neo
having a problem with rb25det neo sump sitting on sway bar, the rb25det neo is a 4wd steaga motor but has been rwd converted shaft been taken out and welded up etc, when i brought the car it was already set up for an rb, was running an rb25de series 0 +t and had crap itself and managed to picked up a rb25det neo cheap, i have read that an a31 cefiro front sway will fix this problem ? has any one else done this conversion before nd how you resolved this problem ?
Your content will need to be approved by a moderator
You are commenting as a guest. If you have an account, please sign in.
Reply to this topic...
×   Pasted as rich text.   Paste as plain text instead
  Only 75 emoticons maximum are allowed.
×   Your link has been automatically embedded.   Display as a link instead
×   Your previous content has been restored.   Clear editor
×   You cannot paste images directly. Upload or insert images from URL.
