Brado_s13
Engine part brands
just wondering, I just bought bc springs and retainers is it okay to buy tomei rocket arms?
Like is it okay to go different brands it should I stick to one?
Yes, don't put bc springs in an sr with vtc. There to stiff. If it's an s13 or s14 series one it will be fine
Nah gonna delete vct so should be sweet
don't be another moron... don't delete VCT...
you also wanted to run a massive f off turbo with a massive f off rear housing
how you going to spool it without low down torque/exhaust flow generated from the VCT increasing cylinder pressure?
Keep vtc. The sr is gutless enough down low with the vtc operational, it will be much worse without it.
(John beat me to it).
Edited by r0berto
Please learn what things are called before buying them and know why you need them or don't buy them until you do actually know why you need a certain part. You will save a awful amount of money by not buying parts that don't work with each other.
I have removed mine vtc with no issues but i have a fully worked head and 272 cams
I tried the Tomei Rocket arms ones & got defected for flying.
  • Upvote 1
if you read what everyone is saying, you'll see its not that it causes problems when you remove it, you just lose any low end torque.
When i say any problems that includes down low torque aswell my power starts coming on early and pulls right the way to the limiter
:lol:
What do you call a "fully worked head"?
Red speckle paint.
Full port and polish biggest valves that will fit, hks 272 exhaust and intake cams.
Not forgetting the red speckle rocker cover 😜
Dont know what else you can do it. Havent noticed any lag as its quite responsive. Also it is set up for drag and has a manulized auto behind it
I was told if you have high power you don't need it?
I'm wanting over 400ho so I was told it won't do anything
which idiot told you that?
VCT doesn't contribute to top end power, but it does everything low end.. it makes the motor produce more low down torque, thus spooling up the turbo earlier, not to mention it will make more power off boost than a motor without VCT.
Like I said earlier on, if you're building a drag car OR a drifter and only sees 5k+ rpm all the time, then VCT isn't really needed.. but you've mentioned in your requirements a motor that isn't laggy
then VCT is a must and a smaller turbo.. your .82 housing and no vct is a recipe for depression and suicide once you've pumped 10k into a laggy piece of shit that would probably get smoked by a mildly modded Honda Civic
Alright I understand bro, what are the biggest cams you can get hat still keeps it?
I know poncams are decent but what size still keeps it?
