GT28RS AFR? - Hardtuned.net
GT28RS AFR?
AFR Gt28rs HKS AFR Sr20det Redtop Disco potato Boost
9 replies to this topic
#1 rlGed^180
  • Car:REDTOP 180SX
Posted 03 March 2012 - 11:42 PM
I was reading on a other post that a gt28rs will damage your engine with out a tune cause of air fuel ratios
My setup on my redtop 180 will be fmic,bov, full exhaust,manifold, gt28rs, apexi pod,profec a and HKS AFR my car has stock injectors and fuel pump
Question is can I boost it to it's maximum potential safely because I have a HKS AFR?
#2 STR8E180
  • Car:GTR R34 V-SPEC
Posted 04 March 2012 - 12:51 AM
http://www.alamomoto.../HKS/hksafr.htm
Is that what u got? I would be adjusting air fuel ratio on a dyno to double check it's safe
If u still have standard injectors and fuel pump u will be limited
If u don't know what your doing pay some one to do it on a dyno for u
#3 rlGed^180
  • Car:REDTOP 180SX
Posted 04 March 2012 - 05:53 AM
Yea that's it. Not many people talk about it on here, Yea I will man this is one thing I prefer not to play around with and when I Finnish putting my car back to gether I'll get it adjusted by a perfeshional
If I was to put A fuel pump and injectors in will the HKS AFR handle/controll the upgrade and avoid me spending money on a PFC
#4 greens14
Posted 04 March 2012 - 08:38 AM
It might work ok bro, but it is a cheap tight arse way of doing it.
Just nistune it and know thT it is tuned properly.
#5 rlGed^180
  • Car:REDTOP 180SX
Posted 04 March 2012 - 09:06 AM
It's true man im tight assing it I'm just trying to work with what I got, the turbo dump pipe and manifold came off a other car for pretty cheap now between baby/house and I want 180-200rwkw I'm just hoping it's all good enough to run safely ( will get it on the dyno I guess like the other bloke suggested cause I don't want to do damage I just don't want to take it there and get told I need a computer )
#6 _R_J_K_
  • Car:Zenki S14
Posted 08 March 2012 - 04:44 PM
You're swapping a pretty major component there. Do it once, do it properly. Wait until you can afford a tune. Nistune's are cheap and good, simply attaches to your stock ECU, and the board costs nowhere near as much as a PFC.
#7 _R_J_K_
  • Car:Zenki S14
Posted 08 March 2012 - 04:53 PM
Also, you'll probably find that it will respond a lot better to the turbo if you get it tuned.
#8 fiend.
Posted 08 March 2012 - 05:30 PM
I wouldn't trust that HKS AFR personally. Your engine is worth quite a lot more than that bit of electronic kit... Although I have to say I haven't tried one and don't know anyone who has.
I'd rather a proper tune by someone I know, that way you can have piece of mind and it will consolidate and make the most out of all the parts you've worked hard to fit.
Edited by fiend., 08 March 2012 - 05:30 PM.
#9 klv180sx
  • Car:1995 Nissan 180sx
Posted 08 March 2012 - 07:48 PM
Absolutely get a tune, everything will run better and there is less chance of anything going wrong...basically what everyone else has already stated.
Good Luck
#10 chris2712au
  • Car:S15gt
Posted 10 March 2012 - 07:12 PM
manipulating the fuel is only half the story.. it will stop the engine from going bang.. but it will mess the timing up.. it isnt all about the fuelling.. and adjusting it will not give much improvement in responsiveness if any.. a disco is a fair size upgrade from a t25.. I would imagine you would start running out of fuel at about 13psi in the top end.. with the stock injectors..
Edited by chris2712au, 10 March 2012 - 07:13 PM.
