GKTECH 4 to 5 stud wheel adapters and 20mm, 25mm and 30mm hub centric wheel spacers at $79/pair - INTRODUCTORY OFFER! Wheels - Tyres
gktech wheel adapters 20mm 25mm 30mm wheel spacers gktech.com.au silvia wheel spacers
5 replies to this topic
#1 GKTECH
Posted 08 February 2012 - 05:29 PM
4 to 5 stud wheel adapters - PRE BUY PRICE - ETA Mid February @ $79/pair
The GKTECH 4 to 5 stud wheel adapters allow a 4 stud car to fit 5 stud wheels. Sold as a pair these wheel adapters bolt on to your standard hub just like a normal wheel spacer however 1 of your standard studs is then replaced with a longer stud which runs through the adapter and acts as the 5th stud. The wheel adapters are hub centric to suit Nissans 66.1mm hub and are manufactured to the highest quality in T6061 Aluminium and then hard anodized to further increase the strength. A super easy and cheap way to make your S13/180sx 5 stud.
Features:
- CNC machined aluminium T6-6061 construction
- Grade 10.9 studs
- Hub centric to suit 66.1mm Nissan hubs
- 114.3mm PCD with M12 x 1.25 thread
- 20mm thick wheel adapters
- Includes extra wheel studs required to install the adapters.
- Sold as a PAIR
FAQ's
What's involved in installing these adapters?
You will need to press a new stud (included) into the hub and then simply bolt on the wheel adapter.
Do you make different sized or PCD wheel spacers?
We only sell the items listed on our website. If it's not listed on our website then we don't make it and we can't help. Sorry.
Are these safe?
These are no different to any other wheel spacer. They are machined from T6-6061 aluminium and are hub centric with grade 10.9 studs. They're strong! That said, as with all wheel spacers or adapters they are not intended or legal for road use.
HOW TO ORDER:
Click the link here and add the item to your cart:
4 to 5 stud wheel adapters: http://gktech.com.au...sp?id=4to5-spcr
4x114.3 and 5x114.3 20mm, 25mm and 30mm wheel spacers @ $79/pair until Sunday Feb 19th
The GKTECH bolt on spacers allow for adjustment of the fitment of your wheels. The wheel spacers are hub centric to suit Nissans 66.1mm hub and are manufactured to the highest quality in T6061 Aluminium and then hard anodized to further increase the strength along with grade 10.9 extended studs.
Features:
- Grade 10.9 studs
- 60mm long studs
- Sold as a PAIR
FAQ's
What torque should the nuts be set to?
As per the Nissan tech guide we recommend a torque setting of between 72-87 Ft. Lbs. Anything more than this will strip the stud and is DANGEROUS. The setting of 72-87 is as per Nissans specifications.
Are these wheel spacers hub centric?
Yes, these spacers have an internal diameter of 66.1mm to suit a Nissan hub.
Are these wheel spacers strong?
Yes, these wheel spacers are very strong. The spacers themselves are manufactured from T6-6061 Aluminium and we use grade 10.9 fittings. That said, please note that these are for off road use and are not intended for use on public roads.
Do you have wheel spacers to suit other vehicles?
No, we only sell the products listed on our website. If it's not listed on here, then we don't sell it. We don’t do any custom work and only sell off the shelf products so can’t make any changes to what is for sale here. Sorry.
Do you have extended wheel studs available on their own?
Yes, we have extended wheel studs available in packs of 10 in our other listings. Please refer to the other listings for more information.
HOW TO ORDER:
4x114.3 20mm spacer: http://gktech.com.au...sp?id=4114-20mm
4x114.3 25mm spacer: http://gktech.com.au...sp?id=4114-25mm
4x114.3 30mm spacer: http://gktech.com.au...sp?id=4114-30mm
5x114.3 20mm spacer: http://gktech.com.au...sp?id=5114-20mm
5x114.3 25mm spacer: http://gktech.com.au...sp?id=5114-25mm
5x114.3 30mm spacer: http://gktech.com.au...sp?id=5114-30mm
cheers,
Greg Kruse - GKTECH
www.gktech.com.au
#2 borgy89
  • Car:96 180sx
Posted 08 February 2012 - 05:46 PM
Hey Greg with the 20mm spacers do you have to cut the remaining studs in the hub shorter to fit wheels? In other words do they poke through the spacer at 20mm cheers
#3 GKTECH
Posted 08 February 2012 - 05:47 PM
That's entirely depandant on your rims as to whether they have the cut out for the stud or not. Most do.
#4 borgy89
  • Car:96 180sx
Posted 08 February 2012 - 06:33 PM
Thanks for the quick reply.
#5 Bejlus
  • Car:Nissan Silvia Onevia (180sx Front)
Posted 24 February 2012 - 12:53 AM
Are these available now?
How long to deliver to Sydney, Australia??
#6 GKTECH
Posted 24 February 2012 - 04:42 AM
 Bejlus, on 24 February 2012 - 12:53 AM, said:
Are these available now? How long to deliver to Sydney, Australia??
For updates on stock availability it's always best to refer to our website as the stock levels and info there is always live.
Delivery is based on which freight option you choose however there is the option of overnight freight (express post).
Greg
