Largest size wheel to fit Silvia S15 - Hardtuned.net
44 replies to this topic
#1 ali_JDM
  • Car:JDM S15
Posted 27 December 2011 - 05:03 PM
Hi everyone,
I want to buy some wheels for my s15, but am wondering what is the largest wheel size i can fit on a Silvia S15 JDM, without scrapping on my guards or anything else,
as I had a wrx with 18s, and every turn the tyre hits the mud guard or something, hate it.
I am looking to get either 18s, 19s or 20s, that would give my s15 a mean & tough LOOK,, which Brand would do that, currently I have front 17x7 AVS T6, and 18x8 Rays, as one of my avs got buckled so had to change the rears.
Any advice or if you had any past experince with wheel size is much appreciated.
Thank you
Edited by ali_JDM, 27 December 2011 - 05:10 PM.
#2 gulrez
  • Car:1996 180sx Type x
Posted 27 December 2011 - 05:12 PM
rimtuck.com
offset thread
whats your suspension setup?
#3 Orphan
Posted 27 December 2011 - 05:16 PM
I am looking to get either 18s, 19s or 20s, that would give my s15 a mean gay look.
Dude.. it's not just about the diameter of the rim, it is also combination of ride height, wheel width and offset and tire choice. There is no reason a well selected wheel will hit the guards. If your wheels were scrubbing on the WRX then either the wheel/tire choice was wrong or your car was too low. There are a billion threads on wheel fitment. Head over to s15oc and check the massive thread on wheel fitment which includes pictures of how they fit and the specs of the wheels and tires on the car.
My advice is to stick to max of 18's, bigger just = more weight and worse ride with no benefit. If big shiney wheels is what you want then perhaps you have the wrong car.
#4 ali_JDM
  • Car:JDM S15
Posted 27 December 2011 - 05:17 PM
Currently got stock suspensions, but also got some adjustable coilovers in my garage which i can install anytime.
I will check that site,
thank you
#5 djhatzigiannis
  • Car:s13
Posted 27 December 2011 - 05:18 PM
legally 1" larger and 1" wider than stock
#6 ali_JDM
  • Car:JDM S15
Posted 27 December 2011 - 05:19 PM
I am not after shiney wheels, I got AVS T6, i am after simillar wheels but with more tough look and mean, I was wondering if bigger like 20s would make the car looks tougher.. cheers
#7 audslz
  • Car:JDM s15 spec R
Posted 27 December 2011 - 05:33 PM
personally 20 inch is too big, unless your into 'sex spec'... hey whatever floats your boat... just downsized from 19'' to 18'' looks much toucher with better fitment
Edited by audslz, 27 December 2011 - 05:34 PM.
#8 Suspop
  • Car:S15 / Megane RS 250
Posted 27 December 2011 - 10:36 PM
This has fail written all over it.
The concept behind wheel fitment is not understood.
19s will make the car look tougher then with 18s... Yeah okay. Was there any mention of offset or tire size that was before - "Edited by ali_JDM"
Edited by Suspop, 27 December 2011 - 10:38 PM.
#9 jadly
  • Car:s15 spec R
Posted 27 December 2011 - 10:56 PM
i had 20 x 9.5 as you can see in my avatar pic, and to tell you the truth mate its too uncumfortable to drive around everday and you can't get traction with the low profile tyres streched over them in the dry let alone when its wet. my advice is to go with what orphan said and stick to some 18's with some decent rubber to match.
#10 ziptie
  • Car:sil80 + a few
Posted 27 December 2011 - 11:06 PM
theres an offset thread on here too, flick through it and see what you like
http://nissansilvia....271829&st=13230
Edited by ziptie, 27 December 2011 - 11:09 PM.
#11 ali_JDM
  • Car:JDM S15
Posted 27 December 2011 - 11:19 PM
rimtuck.com is a very good site,
I love the 18x9.5 +20 for the front, and 18x10 +15 for the rear,
would that be a good hassel free and legal fitment?
I like these as well http://kultivate.wor...8/s15-on-te37s/
TE37 i think,,, what is the difference between TE37, Rota, and Varrstone?
are replica wheels bad??
#12 ziptie
  • Car:sil80 + a few
Posted 27 December 2011 - 11:22 PM
On rimtuck it says what they did to fit the wheels
18x9.5 + 20 and 18x10+15
- Spacers: no
- Fender rolled/pulled: Flared and rolled to suit rims
- Camber:
- Suspension mods: coilovers and all arms
* Tyre 225/40
Unfortunatley it doesnt say how much camber he/she is running.
Fakes are fakes you get what you pay for but yes rota and varrosten rip off te37s.
Edited by ziptie, 27 December 2011 - 11:24 PM.
#13 pman
    Pooh Bear; Wreckin' porcelain since the 90's.
  • Silver Member
  • Classifieds Items
  • PipPipPipPip
  • 1,182 posts
  • Car:RayGay's mum
Posted 27 December 2011 - 11:24 PM
Yes rim tuck is a good site.
Yes those sizes are that of a desirable choice possibly causing that emotion.
No this is not legal and 'hassel' free size combination.
I like it too.
Everything.
Yes.
Cheers also....
#14 -**wHiStLe**-
  • Car:S15, R32, R33
Posted 27 December 2011 - 11:43 PM
17 or 18 X9 + 20ish or 17/18 X 10 +30ish all round will sit nice on a S15.
I have 18X9+20 front and 18X10+18 rear.
The rear pokes a fair bit and needs -3 to -4 to tuck tyre on rolled guards.
#15 Barbie princess
Posted 27 December 2011 - 11:54 PM
17 x 9 and 17 x 9.5.
#16 .Ryan.
  • Car:NA 32 4 Door
Posted 28 December 2011 - 07:07 AM
15x6 15x6.5
#17 Xxx_Ruff_Ryda_xxX
  • Car:Flutterz y0!
Posted 28 December 2011 - 01:21 PM
Every inch will mean that the rim will stick out another 12.7mm and on the inside to the offset of the rim.
The lower the offset, the more desirable in terms of ns rep points. Standard, the S15 has +45 mm of offset which means they are very much tucked into the guards. The higher the offset and width, the more scrub radius. If you want grip, avoid overstretched tyres for a decent sidewall. If it's just looks you want then knock yourself out.
IMO, having 8.5" +30 on the front with 235s (very mild stretch neg 3.5 to neg 4 camber) and having 9.5" on the rear with a similar offset and 265 tyres would my preference with 18" all round with neg 2 to 2.5 camber. All that's needed is some guard rolling and it will only scrub if there isn't enough neg camber or it's too low. For grip that would be a nice setup, IMO it looks tougher than the stretched rim-mexicaned look but others would disagree. I prefer wider tyres myself and the grip that goes with it.
#18 gulrez
Posted 28 December 2011 - 05:33 PM
you shouldnt go for more than -3 camber...for practicality i mean...for looks whatever
#19 14DOT5
  • Car:r33
Posted 28 December 2011 - 06:13 PM
scrubbing and scraping is the name of our game
#20 chris2712au
  • Car:S15gt
Posted 28 December 2011 - 06:54 PM
you have to consider the reasons why and the what you are using the car for..
extra low profile tyres= expensive and harsh ride
Massive rims = easy to damage
Large camber = less inline traction and increased tyre wear
Limited steering capacity
If you are ok with those cons of larger rim setups then go for it..
If you are not going to go stupid with it stay with 18's in sensible offsets / widths..
#21 Xxx_Ruff_Ryda_xxX
  • Car:Flutterz y0!
Posted 28 December 2011 - 07:07 PM
Depends on your alignment. I'm running -3.5 at the front and tyres are wearing nicely. Noticable wear but then you just pop them on the opposing rim (unless you have KU36 or similar tyres).
I can go 18 months until I ned to rotate or change them, that' a daily drive too.
Edited by Xxx_Ruff_Ryda_xxX, 28 December 2011 - 07:08 PM.
#22 gulrez
Posted 28 December 2011 - 09:29 PM
i scrape on full lock
#23 ali_JDM
  • Car:JDM S15
Posted 28 December 2011 - 10:16 PM
true, changed my mind, thanks to all
#24 ali_JDM
  • Car:JDM S15
Posted 28 December 2011 - 10:19 PM
thats what I am after, wheather the 20s will be uncomefortable, i thought s15 would handel bigger sized wheel than wrx..
Your advice is much appreciated buddy, :D cheers
#25 normality
  • Car:S13 - SR20DE
Posted 29 December 2011 - 02:22 PM
 .Ryan., on 28 December 2011 - 07:07 AM, said:
15x6 15x6.5
:wub:
#26 SR20_DET
  • Car:Nissan 180SX - SR20DET
Posted 31 December 2011 - 12:39 PM
About $3,500.
#27 Suspop
Posted 02 January 2012 - 09:54 AM
I like it too.
Everything.
Yes.
Cheers also....
NO they are not bad you db.
#28 ziptie
  • Car:sil80 + a few
Posted 02 January 2012 - 10:21 AM
i wouldnt say 3.5k difference unless youre talking about sl's
a set of rotas is what like 1k - 1.2k?
I sold my set of 17x 9+22 te37s for 2250.
#29 rk2k9
  • Car:200sx S14.5
Posted 02 January 2012 - 10:39 AM
http://tempetyres.co...t=&part_no=2236
these are the rims for you
24inches of goodness
they make the car look TOUGH
they make the car look MEAN
they make the car look SEXY
and they've been proven to direct fit onto s15's
the wheel genius's tempe tyres said so
#30 Gurglar
Posted 02 January 2012 - 11:21 AM
Lies.
Rims can be any size you want aslong as the rim/tyre combo doesn't exceed the stock rim tyre combo, which just means if you get a bigger rim you get a lower profile tyre.
Can also be as wide as you want asliog as you cant see the top of the rim/tyre when looking down over the guard, which means you either flare or get bigger guards.
Anything over 18" on a import looks gay as shit.
Edited by Gurglar, 02 January 2012 - 11:22 AM.
