Bore size with liners - Hardtuned.net
8 replies to this topic
#1 datssr
Posted 11 August 2016 - 11:22 PM
What is the biggest bore size people are running with sr20det Darton sleeved blocks with reliability. Running spool stroker crank and rods.
#2 SpecRS15
Posted 12 August 2016 - 09:38 PM
90mm Also running a spool stroker crank but pauter rods.
#3 blingcommander
  • Car:Scooty-Puff Jr.
Posted 13 August 2016 - 04:15 AM
I was looking into tbis a few years ago and was advised 89.5mm. Give you the chance for a .5 rebore down the track incase disaster strikes
#4 datssr
Posted 13 August 2016 - 02:33 PM
And is 9.0 to 1 compression the most popular choice
#5 Brodie.Maher
Posted 13 August 2016 - 04:57 PM
Depends a lot on setup if you are running on e85 since knock resistance is so good I would sneak it up a bit
#6 datssr
Posted 14 August 2016 - 10:28 AM
Running E85
260/270 cams
EFR7670
#7 The Big Fist
Posted 14 August 2016 - 06:10 PM
Would love to see more of this build !
#8 SpecRS15
Posted 14 August 2016 - 08:18 PM
View Postdatssr, on 14 August 2016 - 10:28 AM, said:
Running E85
260/270 cams
EFR7670
P12 8H6 Head with 2.35L bottom end.
10:1 Compression ratio.
EFR 7670 0.92A/R twinscroll.
I think we'll both find the 7670 a bit on the small side!
#9 nicknack
Posted 15 August 2016 - 05:31 PM
I'm thinking the same with my EFR7163 and 2.2L with OS valves... Will probably be too small.
Yours sound like a match made in heaven for a TS 8374 being 2.35L.
Compression any lower than 9.5:1 for a car running e85 is a waste I think 10:1 is more like it.
