180SX 1JZ-GTE on Apprentice wages - Hardtuned.net - Page 9
180SX 1JZ-GTE on Apprentice wages Silvia
nissan 180180 sx queensland qld australia apprentice build 1jz gte 1jz
253 replies to this topic
#241 pmod
Posted 04 September 2015 - 11:24 AM
View PostDanie l, on 04 September 2015 - 04:21 AM, said:
View Postpmod, on 03 September 2015 - 10:38 PM, said:
It's getting there. Still haven't got it tuned lol, despite having the Nistune, software and most everything else. Recently changed my diff back to a 4.08, and once I've made a proper hotpipe, I'll be set to made some power. Had too little time tbh, moved house and got the flu.
Yeah moving house is a shitload of work especially if you're sick,
that's sick on the 180 sounds super close then, whats your kw goal?
I actually got lucky (still unlucky of course) and came down with the flu the day after I finished moving house and had unpacked/stored a few things.
Don't really have a kw goal to be honest; I got a Hypergear ATR SS2 to match my engine's CR since higher compression needs a bigger turbo to avoid issues, and that unit is rated to 500HP on Stao's website. Chances are I'd need bigger cams, E85 and a bigger fuel pump than a Walbro 250 (or whatever it is I'm running) for that, and I can't really be bothered with that when there are no E85 pumps near me, I already have a fuel pump, and the NA cams I got off a friend during the rebuild are a good match for my CR.
I'd probably be ok with 200kw to be honest, having been driving the car on 1/4 throttle and shifting at 3500rpm for months, so whatever it makes is fine with me. 150kw? 250kw? Who knows. Chances are I'll blow something up whatever I make lol.
What I really want to do is fix my AC blower motor wiring (I think a wire is broken internally), route the air runners around my popup cluster and regas my AC before we reach summer. Priorities...
#242 Danie l
Posted 05 September 2015 - 01:07 AM
Hahah yeah but honestly when are we going to say no to a time that makes sense to upgrade to e85 and bigger cams etc, :P
In my opinion I would run what you have there and add stuff later if it isn't your daily or you're the type of person who says they'll finish something in a night and follows through, lol.
You won't blow it up, it's built well and I'm gonna throw a guess of 265.5kW to wheels exactly :wheelchair:
At least there's a brightside to the sickness, consolidation is having shut down murphey's law lol
Do what's needed most/fun to do first then you'll be in the mood to finish the rest, that's how I work haha
#243 Danie l
Posted 08 September 2015 - 01:14 AM
Never posted pics of when i painted it with dark charcoal hammertone grey, thinned 10% with 10% "tint" of bbq heat black for darkness
pic done by mate
Attached Image: 001.JPGAttached Image: 002.JPG
Attached Image: 003.JPGAttached Image: 004.JPG
#244 Moleman
  • Car:S13 SILVIA
Posted 08 September 2015 - 09:21 PM
ooooooooooooooooohhhhhhhhhhhhhhhhhhhh!
#245 Danie l
Posted 08 September 2015 - 11:12 PM
ahahah
yea boi!!
#246 Danie l
Posted 11 September 2015 - 11:20 PM
Got front all torqued up now so no more f**king with suspension,
Attached Image: 003.JPGAttached Image: 002.JPG
Little cuts to max camber just cus
and best mate did another pic
He does this with spraycans, he's beast as f**k
pm if you want work done by him on gold coast/brisbane
Edited by Danie l, 14 September 2015 - 12:06 PM.
#247 Gough Barry
Posted 17 September 2015 - 09:23 AM
looks so dope with the Graf on the car... your friend is super talented..
#248 Danie l
Posted 18 September 2015 - 02:00 AM
yeah he's an animal bro all forms of art, pencil, tattoo etc
#249 Danie l
Posted 07 May 2017 - 12:37 PM
Project has been rekindled in a new shell with a new motor :o:o
More pics and updates starting again this week :D
#250 Danie l
Posted 14 August 2017 - 08:12 AM
Suspension in, kouki light replacements obtained (need type x beaver)
Posted ImageDoors, hatch, fuel flap and exhaust in (3" straight pipe no mufflers/cat)
Posted ImageFront and rear strut braces in, Front plates torqued to spec, bar left loose for engine bay work. Need to cut old 180sx's upper and lower rad support spot welds out and pop em on here.
Then just need motor+box and to work out the wiring/interior then final touches :D
#251 Ironboy2477
  • Car:Silvia
Posted 09 October 2017 - 07:05 AM
Yeah dude this thread is wicked, keep up the good work! Keen to see what you have in store for the new shell.
#252 Danie l
Posted 11 January 2018 - 12:12 PM
Picking up a motor this arvo. Just need to sort box, fuelling and electrical then will only be a few smalls things to iron out as alot of things are deleted
#253 Briabenia
  • Car:Briabeniaab
Posted 06 February 2018 - 02:44 PM
Cialis Generico Receta cialis Cialis V Levitra Viagra 100mg Dosage Propecia Progesterona
#254 Danie l
Posted Today, 11:28 AM
fitting r32 gtst cluster into s13 dash
Little brackets and zip ties. This is held in by the r32's chassis originally in a 1/4 open metal circle bracket. Since im using branded strong zip ties and the same gauge metal as the stock holder i assume this will be fine. If not it shouldn't be a huge problem to fix anyway. Fingers crossed.
s15 brakes bought
cleaned, serviced and painted. Just used heavy duty floor cleaner and disassembled pad assembly and wire wheel/greased pins. Piston boots look and feel very good condition so left em.
Also installed fuel tank & neck. Still need pump to go into the cradle and new rubber hoses from tank to hardlines (200mm odd at rear subframe)
we've all had sketchy jacking moments, don't lie :D
This was to get height for handbrake cable installation, success and I'm alive so we'll try not to jack like this again :P
lil bracket made from 3mm ally sheet for handbrake cable
Welded lower support bar on, my welding's getting decent now, looks OK and jacked the car from this point a few times and jumped on it to test strength and it didn't even flex so i assume 200 odd kilos of force is all it needs to handle
Unrelated first tattoo home job by myself :D That's some white thigh meat
Manualised steering rack, just remove the rack, fully disassemble (tonnes of guides,) cut off this bracket and reassemble with grease pack.
Bash and/or weld the lines, whatever you see fit, I did both
And done. Guides say this is very hard or experienced but long as you can hang on to a grinder without it getting away and have a socket set you're fine. Very simple, easy and smooth. Reduce your rack preload after manualising, then when car drives test and readjust preload to users preference.
RB20DET
rb 25 cam covers
rb26 cams
box w/ excedy HD
removed clutch fan for s chassis fitment, sorting intake and ex manis then it goes in (maybe even just intake since i can do exhaust easily whilst its in the car)
That's all for now but fairly sure I missed alot as I haven't been updating thread.
I'm working hard as fuck on this thing this week almost every free minute I have.
Shouldn't be long to go now. I will upload a pic of to-do list soon
Today I'm gonna be making brackets for 6" front speakers, install door cards, finish r32 cluster into s13 dash conversion, bolt in front stock seatbelts and aftermarket harnesses and a few small things more.
